Macro Button : Restore Initial gain if gain >= value.
Posted: Sun Aug 30, 2020 11:47 pm
Hi.
X, Y and Z are any hardware track.
Is is possible to :
1- memorise the gain of track X
2- fade gain of X to (ex) -60 if track Y or Z are playing something.
3- fade gain of X back to memorised gain at step1, when Y and Z are not playing.
Actually I have 2 macro-buttons, one for Y and one for Z, both fading X when trigger gain is happening.
The 1st problem is, beside having 2 buttons, I did not find how to memorise the initial gain of track X to restore it.
The 2nd problem : When track Y is triggered while track Z has triggered first, track X is going back up.
Something like (for one button on track Y for instance) :
Initial state required :
Strip(X).gain>-50 //Only if not lower than that (already faded)
Button Trigger IN:
myGain = Strip(X).gain
Strip(X).fadeto=(-60,1000)
Button Trigger OUT:
Strip(X).fadeto=myGain
Unless there is another way. Thank you.
Is is possible to :
Button Trigger IN:
Button Trigger OUT:
