Is it possible to configure Voicemeeter so that the participants in the conversation in Discord and VrChat can hear me and each other through my sound card. I'm currently using Voicemeeter Banana, but I can't avoid echo.
Can Voicemeeter Potato help me or can I customize Banana or is this task basically impossible to solve?
This is also relevant for transferring audio between Discord and Skype or other messengers.
Is it possible to transfer sound between Discord and a video game?
fortgain
Re: Is it possible to transfer sound between Discord and a video game?
Hi. ¿Could you post a screenshot of Voicemeeter Banana to see how everything is connected?
Voicemeeter Banana provides 2 virtual audio inputs which are not enough to control chat, game and system sound independently. You could:
- Use Voicemeeter Potato (3 virtual inputs)
- Add a VB-Cable (Virtual Audio Cable) and use it with Voicemeeter Banana
fortgain
Here, the Foobar audio player transmits sound to VrChat and Discord via VoiceMeeter AUX at normal volume, and transmits sound to the headphones via CABLE Output with a reduced volume level (-7.9).
If I change the Output device in Discord from default to VoiceMeeter AUX Input, then VrChat's participants hear Discord's participants, but Discord's participants hear the echo of their voices.
Alternative virtual cable Line 1 (Virtual cable) in HARDWARE Input 3 is not involved now and I do not know if it can be useful to me.
Can I solve the problem with Voicemeeter Banana or I need a third VIRTUAL INPUT in Voicemeeter Potato?
in your setup, Discord gets audio from Voicemeeter virtual output = BUS B1...
so all sources sent to BUS B1 will go in Discord.
you must not send Discord output in BUS B1 (Discord plays back in Voicemeeter Virtual AUX input) !!!
fortgain
I understand that. Therefore, I do not use this setting on Discord, because VoiceMeeter AUX Input normally transmits Discord's audio to VrChat without echoing, but participants of Discord hear an echo of their voices. And I need to transfer sound to VrChat and without echo to Discord. Usually my Discord sends audio to VoiceMeeter Input and there is no sound transmission between Discord and VrChat.Vincent Burel wrote:in your setup, Discord gets audio from Voicemeeter virtual output = BUS B1...
Hi. You need one output to send audio to Discord and a different one to send audio to VRChat (It seems like you are currently using B1 output = VoiceMeeter Output in both programs). Your options include:
- Use B2 to send audio to Discord: Are you currently using B2?
- Use Line 1 (Virtual Audio Cable) to send audio to Discord: This requires to remove it from Hardware Input 3 and selecting Line 1 (Virtual Audio Cable) as your Input Device in Discord
fortgain
Andreas, Hi, and thank you very much for your help!
According to your instructions, I tuned and tested the sound on two computers and now everything works perfectly.
Indeed, B2 was not used, and now everything is involved.
Interestingly, what if in this way I still need to connect Skype, then I already need Voicemeeter Potato?
Hi. Nice to hear you configured Voicemeeter according to your needs. Adding Skype requires an additional input and output to avoid loops. I think you are using all the available outputs but maybe I am wrong. ¿Could you please share an additional screenshot to review?
Voicemeeter Potato provides additional features which could simplify and provide more flexibility in your setup (for example setting a different volume level for the media player in each output).
fortgain
Hi. I can't find a solution using only Voicemeeter Banana. Connecting Skype requires an additional virtual input and output which is not available. Using an additional Virtual Audio Cable you could try a more complex setup but I think you should try to simplify your setup instead of adding more components to it. If you depend on Voicemeeter Banana I could try to describe this alternative. Please let me know.
