OK,
I'm running Voicemeeter Potato.  I have MIDI enabled and Macros enabled.  I would like to know the proper way to retain the settings between sessions.
There is a settings file for MIDI, another settings for Macro.
Right now for initial state on one of the Macro buttons I have the following. The first is for making sure all of my inputs and outputs are correct.
The second is to load the Macro Buttons (although I'm not sure how it loads since the Macro Buttons must be loaded before this command to work anyway.
The third is for my MIDI mapping my MIDI controller
Am I overcomplicating things or is it supposed to remember all of this without adding these commands?
Is there just a single file location that already retains all of this?
Command.Load="C:\C2-Disk\Documents\personal\VoiceMeeter\Main-All-Speakers-2020-09-08.xml"
Command.Load="C:\C2-Disk\Documents\personal\VoiceMeeter\buttons-2020-09-04.xml"
Command.Load="C:\C2-Disk\Documents\personal\VoiceMeeter\MIDI-apc-40-2020-09-03.xml"
