feature request/question Virtual Asio Input to Hardware Out resampling
Atg
Is it possible to force virtual input to work in asio mode on whatever requested (by DAW) samplerate and let Voicemeeter resample to samplerate that Hardware out is using? For example if I want to create a project in DAW with 96khz or 192khz samplerate (for more precise pitch changing, effects, etc) but I use my audio interface in voicemeeter at 48khz (in asio mode) and I cant change samplerate on device intself for some reasons (like device dont support high samplerate or have something connected through adat that operates on fixed samplerate).
Re: feature request/question Virtual Asio Input to Hardware Out resampling
no Voicemeeter Virtual ASIO driver are stricly synchronized on the Voicemeeter main stream , so with the same samplerate and buffer size than output A1 device.
Atg
Well, will ASIO resampling be added at some point in future?
will think about...
