Hardware input will not play thru the selected output
Addrok93
Post by Addrok93 »
I have an issue . I have a Numark all in one mixer hooked to my stereo which has a usb interface. Voicemeeter can see this so I choose it for hardware input 2 and have my stereo as my A1. I can't get the input meter to show activity when the music is playing Even if A1 or A2 are booth on. This is my only issue everything else works. Is there something I am missing or is there a routing issue? Please any help someone could give would be greatly appreciated.
Re: Hardware input will not play thru the selected output
Hi. Could you please provide additional info about your stereo (Brand, Model) and mixer (Model)? If I understand correctly you are connecting your Numark mixer to one input of the stereo (possibly through RCA/Phono connector) and then you connect the stereo to your computer (via USB). Could you describe what are you expecting from using Voicemeeter?
