Can not un-install Virtual HIFI Cable
GBeutler
Post by GBeutler »
I've been testing HiFi Cable. After Installation I've had two (!) virtual input and output. I was thinking, it's normal but then had a routing problem between VB Hifi Cable and Zoom.
For this reason I thought, best would be to re install. After executing the VB audio installer one in and one out endpoint has been removed, the one with the leading "2-" but the other one is still there.
The installer still reports Asio Bridge and HIFI Cable are already installed. So everything gotr partially removed but now stucks in the middle.
I've tried several times and also executed it as administrator and did a reboot each time. No change yet. Also I can see it in the sound settings :
screenshot 3
screenshot 3
screenshot 1
screenshot 1
screenshot 2
screenshot 2
Could someone tell how to proceed please, I am somehow trapped and can't get back or forth.
What I was trying to set up was 2 channels one for Keyboard -> OBS and then from OBS -> Zoom. I was thinking, based on the description, HiFi Cable is made for this.
Thanks in advance for your kind support and best regards,
Guido
Re: Can not un-install Virtual HIFI Cable
Hi Guido. Hi-Fi Cable installer puts some files in this folder: C:\Program Files (x86)\VB\ASIOBridge. When you run the uninstaller it should delete all files from that folder (except for the installer itself). Is it currently empty?
You can also check Voicemeeter (also from VB-Audio) to try to solve your audio routing needs.
you may re-install it correctly, because it appears with the wrong icon.
follow recommendation there:
viewtopic.php?f=7&t=688
GBeutler
Post by GBeutler »
Hi @Andres, yes
is empty but the folder exists. Now trying unsinstall in device manager
GBeutler
Post by GBeutler »
Ok so followed the recommendation from Vincent:
device manager looks like this:
2020-11-24 20_00_17-Window.png (36.9 KiB) Viewed 32748 times
I de- installed both entries, after that, prior re- boot it looks like this:
2020-11-24 20_02_34-Window.png (32.77 KiB) Viewed 32748 times
Re- boot -> they are back, screenshot 1. A refresh after de- installation leads to the same.
I do not manage to get rid of them.
Hi Guido. In addition to the Audio inputs and outputs devices, uninstall the VB-Audio Hi-Fi Cable controller. It is located under Sound, video and game controllers. Windows should ask you to reboot your computer.
Sound, video and game controllers.png (29.83 KiB) Viewed 32741 times
GBeutler
Post by GBeutler »
Confirmed, worked. After uninstalling the Controller it was gone. Thanks!
