So, I've been trying to figure out a way to create a shortcut key using the key combination of Numpad Mult and Numpad 1 to activate a macro within voicemeeter potato. At first I used the *+ Numpad 1 option in the dropdown list, but it seems that this does something else. If there is a way to define custom shortcut keys for macros such as the example above, could someone please tell me how?
Thanks,
Geno
Is there a way to define custom shortcut key strings to activate macros?
Its_geno
xcasxcursex
Re: Is there a way to define custom shortcut key strings to activate macros?
I'm not sure why the numpad 1 isn't working for you, it works fine here. Did you forget to enable numlock? If I set numlock off, it doesn't work (as expected since we're not hitting numpad 1 we're hitting numpad end!)
Anyway, it would be REALLY nice to have a more flexible shortcut selection. Combined multipliers, custom keycodes, etc....
