Greetings,
I had installed the Banana verision of which worked well with my Win 10 PC.
Now, when I startup the software, my compter goes to the dreaded blue screen.
I have tried to uninstall and reinstall the software, but still crashes.
Any help would be appreciated.
Stan
Voicemeeter causing computer crash after startup
Stan_h
nsf323
Re: Voicemeeter causing computer crash after startup
I've seen your post re Blue Screen
Did you resolve this issue? as it has just happend to me having moved from Win 10 to Win 11
assuming you are using the latest Voicemeeter version (x.1.1.9),
we have a single report about BSOD at the moment and it is due to a particular version of Logitune.
just remove or update this Logitech application, that is disturbing the Windows Audio Stack in a very strange way.
