VBAN is awesome, thank you!
I'm having a problem where the VBAN Receptor app for Android goes to sleep after 5 minutes. This happens even if the app is excluded from the "battery saver" functionality.
A workaround I'm using is using another app to keep the device awake:
https://f-droid.org/en/packages/info.zw ... feinetile/
My question is, does the Android app use a "wake lock" to prevent this from happening?
https://developer.android.com/guide/top ... #wakelocks
Thank you.
