conflict voicemeeter Win Amp
EzBios
Post by EzBios »
Hello I come towards because after having made all the manipulations of reinstallation of the cables as well as voicemeeter to uninstall one by one the cables then voicemeeter I always have the same problem I put it to you in video so that it is more explicit and that you understand better what it is about here the video if somebody has a solution https://www.youtube.com/watch?v=br9Mho4 ... e=youtu.be cordially https://www.youtube.com/watch?v=br9Mho4 ... e=youtu.be
Re: conflict voicemeeter Win Amp
Hi. You could try to select the desired playback device directly from Winamp. Go to Preferences (Ctrl + P) - Plug-ins - Output and choose the Nullsoft DirectSound Output. Click on Configure and select the desired device (CABLE-A Input).
Winamp Output device.png (16.05 KiB) Viewed 5977 times
I don't speak French so excuse me if I don't understand correctly your issue.
Hope this helps. Please let us know if you need additional help.
EzBios
Post by EzBios »
wow you're a magic this is exactly what I was looking for I didn't know I could find the win amp outputs by clicking on this button thank you very much
