does anyone know how to access 8 channels to be able to record in 8 tracks?
I paid $ 30
access to 8 channels
Re: access to 8 channels
Hi. Could you please describe your setup a little further? Do you need to record using a DAW? What version of Voicemeeter are you using?
2 way to record 8 tracks:
- with the integrated recorder (Banana & Potato), configured in 8 channel and getting audio from output BUS.
- with an ASIO application (DAW) connected to Voicemeeter virtual ASIO driver.
REM: our virtual windows audio device interface allows 8 channels only on Windows XP (after VISTA, our audio driver interface is limited to 2 channel by Windows).
