Potato CPU Prolonged Spike
TheVoice
Post by TheVoice »
I noticed recently Potato is using a high amount of CPU. This state is continuous. This can't be considered normal?
Potato Drain.PNG (47.48 KiB) Viewed 7389 times
Potato Settings.PNG (96.69 KiB) Viewed 7389 times
TheVoice
Re: Potato CPU Prolonged Spike
Post by TheVoice »
Removing the Charge 4 Bluetooth speaker from A4 reduced CPU load to 15-16%. And the speaker was not even in use or connected when it displayed the over 40% load. Is this to be expected? Seems high to me.
Edited to add: There seems to be some useful info to reduce CPU load given by Vincent at this thread:
viewtopic.php?f=6&t=1382&sid=d5585db797 ... 25da1cfcef
yes, some device can generate important wait cycle (it's not the first time we got such feedback with BT device).
