BSOD: vbaudio_vmauxvaio64_win10.sys
Snacko
Post by Snacko »
I have been using VB for a few years. I liked it so much I even donated after testing it out. It's been working fine for over 3 years, but I upgraded my mb, gfx, and cpu and installed a clean copy of Win 10 Home x64 and had it up and working fine for about 3 weeks.
I use VB to send audio shaker sound files (in stereo), from an app called SimShaker, to VB and then onto my shakers on my sim pit.
SimShaker(stereo) -> VB -> Audio Card for Shakers
Last week I decided to try the 5.1 channel option of SimShaker, which required ASIO4ALL drivers. It's setup and working fine
SimShaker(5.1) -> ASIO4All -> VB -> Audio Card for Shakers
Now I get this BSOD error after about 5-10 minutes. It all works fine, and then the BSOD! I searched and found that .sys file in the c:Program Files(x86)\VB \Voicemeeter folder. And in the C:\Windows\System32\drivers folder.
Stop code: DRIVER_IRQL_NOT_LESS_OR_EQUAL
What Failed: vbaudio_vmauxvaio64_win10.sys
Is there an option in VB that I need to set for the shakers input? I know how to do what I want, but I'm not an expert at all with VB(it can do so much more than I use it for.)
I ran the VB Device Checker and the report is below... :)
INPUT DEVICE: 10
IN WDM Headset Mic (3- USB Audio Device) | USB\Class_01 | {86d072ac-ed0f-4b02-8561-0cce4a680c21} | ICON: C:\WINDOWS\system32\mmres.dll,6
IN WDM Reverb G2 Mic (Realtek USB2.0 Audio) | USB\VID_0BDA&PID_4C15&REV_0009&MI_00 | {49dc81bd-1630-4de1-b461-aeaa3bb417b2} | ICON: C:\WINDOWS\system32\mmres.dll,6
IN WDM VoiceMeeter Aux Output (VB-Audio VoiceMeeter AUX VAIO) | VBAudioVMAUXVAIO | {907f3569-a225-4d80-8f6e-d726aad55824} | ICON: %windir%\system32\Drivers\vbaudio_vmauxvaio64_win10.sys,-101
IN WDM VoiceMeeter Output (VB-Audio VoiceMeeter VAIO) | VBAudioVMVAIO | {5f16f043-7697-4854-b60a-a4c307e00a25} | ICON: %windir%\system32\Drivers\vbaudio_vmvaio64_win10.sys,-101
IN KS  VoiceMeeter Aux vaio | VBAudioVMAUXVAIO | \\?\root#media#0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
IN KS  VoiceMeeter vaio | VBAudioVMVAIO | \\?\root#media#0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
IN MME Headset Mic (3- USB Audio Devic |  |  | ICON:
IN MME Reverb G2 Mic (Realtek USB2.0 A | USB\Class_01 | {49dc81bd-1630-4de1-b461-aeaa3bb417b2} | ICON: C:\WINDOWS\system32\mmres.dll,6
IN MME VoiceMeeter Aux Output (VB-Audi | VBAudioVMAUXVAIO | {907f3569-a225-4d80-8f6e-d726aad55824} | ICON: %windir%\system32\Drivers\vbaudio_vmauxvaio64_win10.sys,-101
IN MME VoiceMeeter Output (VB-Audio Vo | VBAudioVMVAIO | {5f16f043-7697-4854-b60a-a4c307e00a25} | ICON: %windir%\system32\Drivers\vbaudio_vmvaio64_win10.sys,-101
OUTPUT DEVICE: 14
OUT WDM 5.1 Surround Speakers (Realtek(R) Audio) | HDAUDIO\FUNC_01&VEN_10EC&DEV_1220&SUBSYS_104387C4&REV_1001 | {6c113652-2001-48ba-a3f8-894fc99c12ac} | ICON: %windir%\system32\mmres.dll,-3010
OUT WDM Headset (3- USB Audio Device) | USB\Class_01 | {715be4fd-8039-4b39-be62-e3c6aa818001} | ICON: C:\WINDOWS\system32\mmres.dll,6
OUT WDM Shakers (Sound Blaster Audigy Fx) | HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_11020041&REV_1000 | {33520a06-1eb4-4120-b4cc-2a4225871331} | ICON: C:\Windows\system32\mmres.dll,9
OUT WDM VoiceMeeter Aux Input (VB-Audio VoiceMeeter AUX VAIO) | VBAudioVMAUXVAIO | {4c4354f2-34c5-47b5-bc68-6f53bb7c359e} | ICON: %windir%\system32\Drivers\vbaudio_vmauxvaio64_win10.sys,-100
OUT WDM VoiceMeeter Input (VB-Audio VoiceMeeter VAIO) | VBAudioVMVAIO | {15b62331-cf8a-4d7d-92eb-3aced10e75b0} | ICON: %windir%\system32\Drivers\vbaudio_vmvaio64_win10.sys,-100
OUT KS  Realtek USB2.0 Audio | USB\VID_0BDA&PID_4C15&REV_0009&MI_00 | \\?\usb#vid_0bda&pid_4c15&mi_00#7&1d214645&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global
OUT KS  USB Audio Device | USB\VID_0D8C&PID_0014&REV_0100&MI_00 | \\?\usb#vid_0d8c&pid_0014&mi_00#8&3a1b90aa&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global
OUT KS  VoiceMeeter Aux vaio | VBAudioVMAUXVAIO | \\?\root#media#0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
OUT KS  VoiceMeeter vaio | VBAudioVMVAIO | \\?\root#media#0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
OUT MME 5.1 Surround Speakers (Realtek( | HDAUDIO\FUNC_01&VEN_10EC&DEV_1220&SUBSYS_104387C4 | {6c113652-2001-48ba-a3f8-894fc99c12ac} | ICON: %windir%\system32\mmres.dll,-3010
OUT MME Headset (3- USB Audio Device) |  |  | ICON:
OUT MME Shakers (Sound Blaster Audigy F | hdaudio\func_01&ven_10ec&dev_0899&subsys_11020041 | {33520a06-1eb4-4120-b4cc-2a4225871331} | ICON: C:\Windows\system32\mmres.dll,9
OUT MME VoiceMeeter Aux Input (VB-Audio | VBAudioVMAUXVAIO | {4c4354f2-34c5-47b5-bc68-6f53bb7c359e} | ICON: %windir%\system32\Drivers\vbaudio_vmauxvaio64_win10.sys,-100
OUT MME VoiceMeeter Input (VB-Audio Voi | VBAudioVMVAIO | {15b62331-cf8a-4d7d-92eb-3aced10e75b0} | ICON: %windir%\system32\Drivers\vbaudio_vmvaio64_win10.sys,-100
CHECKING VB-Audio Cable A : Not Installed
CHECKING VB-Audio Cable B : Not Installed
CHECKING VB-Audio VoiceMeeter VAIO3 : Not Installed
TEST DATE: 2021/02/23 - 22:49:24 (Checker Version 1.0.7.4)
Operating System: WIN 10 64Bits Build: 19042
CONCLUSION: OK (nothing bad detected)
Re: BSOD: vbaudio_vmauxvaio64_win10.sys
I see 2x possibilities:
1- the audio stack has been corrupted by the last driver/device installation but our DeviceChecker does not see it (this is testing our driver only).
2- you are using a special option in Voicemeeter system settings (WDM Input Exclusive mode or Engine Mode : must be NO and NORMAL).
Snacko
Post by Snacko »
Thanks for the reply and trying to help. Both of those settings in the Special Options were as you said. NO and Normal. I never have touched any of the Special Settings, ever.
I fixed it though.. :D My Simshaker app doesn't have any settings I can change for ASIO. When I select the 5.1 option, it just disables the audio selection box and it says it's using ASIO.. ASIO4ALL has a user interface and automatically launchs it into the SysTray when an App is using ASIO. I had selected VB AUX as the device, but it had a [+] to expand the In/Out options. They were both selected, so I turned the Out off and figured I was sending ASIO 'In' to VB. But that didn't work. When I only selected the Out, it seems to be fixed!!
Time will tell. Thanks again.
Snacko
