Voicemeeter crashing repeatedly on Win 10
Posted: Mon Mar 22, 2021 9:40 am
Setup:
- Potato 3.0.1.4.
- BT Headset (WDM)) as A1
- 2 other speakers (WDM) as A2/A3 (generally not used)
- Win 10 Pro
Symptoms:
The potato app and Audio device crashes a few times a day. As I'm generally walking around with my bluetooth headset on (paired to my phone and PC), it disconnects when I get too far from my PC and sometimes (not always) VB-Audio has crashed when I get back and I need to force kill and restart it. This happens with different bluetooth headsets
I've found the below in the event viewer but I can't find any other logging that might indicate a cause. This has been happening since I set up VM a few months back.
Any thoughts?
EventViewer Logs:
The program voicemeeter8.exe version 3.0.1.4 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
Process ID: 311c
Start Time: 01d713f70aba5a44
Termination Time: 4294967295
Application Path: C:\Program Files (x86)\VB\Voicemeeter\voicemeeter8.exe
Report Id: d961941e-5cf8-4e24-867d-12b21ef639aa
Faulting package full name:
Faulting package-relative application ID:
Hang type: Top level window is idle
I also see the following for Macro Deck:
Faulting application name: Macro Deck Server.exe, version: 1.3.0.23, time stamp: 0x5cb0c848
Faulting module name: KERNELBASE.dll, version: 10.0.19041.804, time stamp: 0xb610d74d
Exception code: 0xe0434352
Fault offset: 0x0012a8b2
Faulting process id: 0x398c
Faulting application start time: 0x01d713f706b80408
Faulting application path: C:\Program Files (x86)\Macro Deck\Macro Deck Server.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: 244b7254-429d-4bfe-811b-ff217d8887da
Application: Macro Deck Server.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.UnauthorizedAccessException
at System.IO.__Error.WinIOError(Int32, System.String)
at System.IO.Directory.InternalCreateDirectory(System.String, System.String, System.Object, Boolean)
at System.IO.Directory.InternalCreateDirectoryHelper(System.String, Boolean)
at System.IO.Directory.CreateDirectory(System.String)
at Macro_Deck_Server.ThemeManager.Initialize()
at Macro_Deck_Server.ThemeManager..ctor()
at Macro_Deck_Server.Main..cctor()
Exception Info: System.TypeInitializationException
at Macro_Deck_Server.CrashReport..ctor(System.String)
at Macro_Deck_Server.Program.CurrentDomainOnUnhandledException(System.Object, System.UnhandledExceptionEventArgs)
- Potato 3.0.1.4.
- Win 10 Pro
Symptoms:
Any thoughts?
EventViewer Logs:
Process ID: 311c
