I'm using Potato. I would very much like to have Inserts on the A1-A5, B1-B3 Outputs. I.e. a virtual ASIO insert for the busses.
I've found a similar request from a couple of years ago, see topic https://forum.vb-audio.com/viewtopic.php?p=2508
My use case is similar to the one in that topic; I'm in charge of all things technical at a community radio station.
A1 goes to the studio monitors, A2 and A3 to two different sets of headphones, A4 to a big stereo in a room outside the studio and A5 to a recording system. B3 is streamed to the transmitter site. All the outputs require different processing.
The poster in that earlier topic insisted on the Inserts for the Outputs to be in the same ASIO driver as the Inserts for the Inputs. That seemed to make it difficult to implement.
I don't need that, though. I'm using Cantabile Performer as my VST host and I can run several instances of it. I would be perfectly happy with a separate ASIO driver for Output Inserts.
Ragnar
Feature request: Inserts for the outputs
ragnar.jensen
