Hi, I use the VB-Cable alongside Pedalboard2 to calibrate my headphones systemwide with VST plugin to match the Harman EQ target. When I set Windows' output to VSC the voume buttons stop working, just mute works. To change the volume I need to set Windows audio out to my soundcard, change the volume to the desired level and change it back to VBC. Is there any way to make the volume adjustment working with VBC?
Windows 10 x64
Focusrite Scarlet Solo USB soundcard
Volume control not working
Re: Volume control not working
Hi. Thank you for using this support forum. VB-Cable does not support a volume control (Windows will show you a volume level control but it is not implemented in VB-Cable).
This previous post has related information: https://forum.vb-audio.com/viewtopic.php?f=7&t=1036
