Hello, I'm trying hard to connect the new (beta 3.0.2.0) VB-Streamer to control the volume of a remote computer. Using local config works well but when I change to a remote IP I get "Voicemeeter is not responding to VBAN#1" and got this MSG .
My configuration is:
Local computer ip:192.168.1.101
remote computer ip:192.168.1.102
I also tried to change the port on both computers to something else like 6301 and I got audio streaming, macrobuttons with midi working but not the streamer-view.
AM I doing something wrong? Help Please!
Thanks
NEW VB-Streamer not connecting to remote computer
Jubis_1963
- Not respondog.png (6.45 KiB) Viewed 31672 times
Re: NEW VB-Streamer not connecting to remote computer
if you run the streamer view to use it with VBAN connection, you may shutdown VBAN on Voicemeeter because on a given computer, 2x applications cannot use the same UDP port.
Jubis_1963
I turned VBAN off on voicemeter
on both computers, turned off Macrobuttons on both too
and still can't connect, only locally!
Jubis_1963
Fixed! Thanks...
Found out that I can set separate ports for outgoing! So I changed computer with IP 192.168.1.101 to send at 6302 and computer 192.168.1.102 to send at 6301. that did it.
But the VM-Streamer besides ON isn't controlling the audio on the remore computer!
Can I set # ports for incoming? I tried to change one but when I do they change for all Streams!
Thanks
Thanks
- VB Streamer ON.png (16.79 KiB) Viewed 31667 times
Jubis_1963
Justto illustrate what I said, connection OK but controll not working. I zeroed the MAIN (computer) and the sound was still full.
Jubis_1963
Made it to work just renaming Command1 to somtehing else! It WORKS! super
