Hello everybody
I need help to perform an ALT+TAB command on a remote computer, The ALT key would the to be pressed and a 2nd button would perform the switch until the TAB key is OFF.
I've been trying and I managed to get the alt+tab done but I can't just perform the tab to switch the app.
The ALT down is done this way
And the
TAB is done like this:
Thanks
Is it possible?
Perform ALT+TAB to switch active program on a remote computer
Jubis_1963
Re: Perform ALT+TAB to switch active program on a remote computer
you may use
System.KeyDown("ALT+TAB"); instead no ?
and of course
System.KeyUp("ALT+TAB"); in button OFF script
and of course
Jubis_1963
I tried, ALT+TAB open the ALT+TAB windows app switch but then I need to press another tab to switch the selected App, the problem is that second tab.
I do System.KeyDown("ALT+TAB"); in a 2 positions button type to open the ALT TAB menu but how do I manage to do the TAB to switch the app?
I tried programming another button with either System.KeyDown("TAB"); or System.KeyPress("TAB"); but neither works!
