MT128 VBAN-TEXT command
MT32-Sound Pad Lite
SOUND PAD Instruction set:
Play the Sound number 6
SoundPad.Button(6).Play =1;
Stop the Sound number 6
SoundPad.Button(6).Play =0;
Stop All SoundPad Sounds
SoundPad.StopAll =1;
Load an audio file in SoundPad Button
SoundPad.Button(1).Load =”F:\MediaFolder\audiofile.wav”;
PLAYLIST Instruction set
Start first playlist
Playlist(1).Play =1;
Stop first playlist
Playlist(1).Play =0;
Stop All Playlist
Playlist.StopAll =1;
To Select the Sound item 5 in PLaylist 2
Playlist(2).Select =5;
To Play the Playlist 2 by the Sound item 7
Playlist(2).Sound(7).Play =1;
Load an audio file in Playlist Item:
Playlist(1).Sound(4).Load =”F:\MediaFolder\audiofile.wav”;
TIMELINE Instruction set:
Play TimeLine
Timeline.Play =1;
Play TimeLine Cue index 2 (cue index – as displayed in the CUE Panel).
Timeline.Cue(2).Play =1;
Play TimeLine Marker ident 2 (marker ident).
Timeline.Marker(2).Play =1;
Goto TimeLine Cue index 2 (cue index).
Timeline.Cue(2).Goto =1;
Goto TimeLine Marker ident 2 (marker ident).
Timeline.Marker(2).Goto =1;
Stop TimeLine
Timeline.Stop =1;
Pause TimeLine
Timeline.Pause =1;
Rec TimeLine
Timeline.Rec =1;
TimeLine REW
Timeline.Rew =1;
TimeLine FF
Timeline.Ff =1;
Goto TimeLine (hour, minute, second. and optionally millisecond).
Timeline.Goto =00:00:00;
Timeline.Goto =00:00:00.000;
MT128 VBAN-TEXT System command
System Execute
This function works like a “CreateProcess” or SheelExecute under windows and allow to start any application with a command line argument.
System.Execute(szprogram, szworkdir, szcommand);
Example to open a web page with the internet explorer:
System.Execute("C:\Program Files\Internet Explorer\iexplore.exe", "","-new www.voicemeeter.com");
Special chars like double quotes can be inserted by this sequence %’ (percent + simple quote): then %’ will be replaced by “. To insert a percent char, simply enter it double: then “%%” will be replaced by a single ‘%’. %; will be replaced by ';'
ENVIRONMENT VARIABLES
It is also possible to use system environment variable by using %envname% syntax.
Example to run the Microsoft WRITE Editor application
System.Execute("%windir%\write.exe","%TMP%","");
RUNNING DOS APPLICATION
To run command line program, you need to launch cmd.exe with /K command to specify you want to execute the command after…
Example to run ipconfig in a DOS window:
System.Execute("%windir%\system32\cmd.exe","%windir%\system32","/K ipconfig");
/C Carries out the command specified by string and then terminates
/K Carries out the command specified by string but remains
Example to ping your internet router (usual address is 192.168.1.1):
System.Execute("%windir%\system32\cmd.exe","%windir%\system32","/K ping 192.168.1.1");
System KeyDown / KeyUp / KeyPress
This functions allow to send a combination of 1 to 4 keys by a simple string describing this keyboard combination, like “CTRL+SHIFT + F10” or simply “0”.
System.KeyDown(szKey);
System.KeyUp(szKey);
Example:
System.KeyDown("A");
System.KeyDown("SHIFT+T");
System.KeyUp("A");
System.KeyUp("SHIFT+T");
System.KeyDown("CTRL+NP1");
System.KeyDown("ALT+F8");
System.KeyUp("CTRL+NP1");
System.KeyUp("ALT+F8");
KeyPress function send Down and UP message in a single function.
System.KeyPress("CTRL+NP1");
System.KeyPress("ALT+F8");
List of Key Name:
