VBAN/MacroButtons increase/decrease Option.Delay() possible?
Snapper
Post by Snapper »
Hi there,
is there a possibility to increase/decrease the Option.Delay() for an BUS via VBAN/MacroButtons like it works with Volume etc?
I expect 'Option.Delay(0) +=1' to increase Delay on A1 for 1ms but instead it just set it to the given value (1ms). I also noticed, when i change or actually set) the Output.Delay via VBAN or MacroButtons, everytime i send the command the audio-engine restarts - which means audio playback interrupts for 1-2 seconds. When I set/change the Delay directly in the Options, nothing interrupts and the new delay instantly active and smoothly transists.
Re: VBAN/MacroButtons increase/decrease Option.Delay() possible?
ok, i note your request for next update.
Snapper
Post by Snapper »
Sounds great, thank you!
Looking forward the next update :)
