Hi, I haven't found a API description for that commands I can set on the VBAN Buttons.
The Pinned Documents at start of this forum seem to describe the low level network protocol for programmers.
Can I send that same commands as for the buttons to some telnet port in linux shell way too?
VBAN API Spec (Buttons App)
Re: VBAN API Spec (Buttons App)
VBAN-Button instructions are basically the same than MacroButtons (you can find in the Voicemeeter User Manual).
https://vb-audio.com/Voicemeeter/Voicem ... Manual.pdf
