Connection Problems
Posted: Mon Jan 10, 2022 3:34 pm
by HGA1
Voicemeeter 1.0.8.1
Win 10 as a virtual machine in a Windows Domain, new installation
Ping in both direction works
Firewall is free for UDP 6980 and Voicemeeter
There is no HostName displayed
Right click on HGA: IP-Address used: not found
The same when I use the IP
Also no Incoming Stream detected
Vincent what could be the problem?
What are the requirements for VBAN?
How can I test the requirements?
Re: Connection Problems
Posted: Mon Jan 10, 2022 8:40 pm
you may try to enter the IP-address directly...
maybe your 2x Devices are not on the same network or there is fierwall activated on your PC's...
Posted: Wed Jan 12, 2022 4:23 pm
by HGA1
Hello Vincent,
that was a stupid mistake, I just forgot to switch on VBAN. :D
Posted: Wed Jan 12, 2022 8:48 pm
yes, right, i did not see it :-)
