BUG: MacroButtons multiple state changes
tarosk
Post by tarosk »
I have following 2 lines in Trigger IN section:
Button(40).State = 1
Button(41).State = 1
Problem is that if Button(40).State already is 1 second line is not executed.
Re: BUG: MacroButtons multiple state changes
cannot reproduce, what is your MacroButtons version ?
tarosk
Post by tarosk »
Version 1.0.4.0
Attaching respective buttons configuration.
and what about the button 41 ?
tarosk
Post by tarosk »
it's basicaly the same as button 40 (attached)
Anyway I found I was not changing state of buttons but Mute in VoiceMeeter, so button state was de-synchronized with VoiceMeeter
Workaround is to use this sequence in button 02 to force button 40 and 41 state and button-on command execution:
Button(40).StateOnly = 0
Button(41).StateOnly = 0
ok, and the fact you want to control 2 position Button with a Push button is maybe not as consistent as it could in term of behavior.
tarosk
Post by tarosk »
I needed keys to uncoditionally mute and umute my mikes and at the same time sync LEDs on my midi controler. Have not found better way to achieve this. 🤷‍♂️
