No Stream
shofotolagski
No Stream
Post by shofotolagski »
VBAN-Receptor The iphone can't connect to the host, but the ipad is available
info won't light up
VBAN receptor version 1.7, ios store Hong Kong, mobile iPhone 6plus model NGAA2CH/A, ios 12.5.5
Software is the latest version
屏幕截图 2022-04-07 225513.jpg (76.19 KiB) Viewed 76546 times
屏幕截图 2022-04-07 225720.jpg (203.98 KiB) Viewed 76546 times
2022-04-08 083951.png (207.04 KiB) Viewed 76546 times
shofotolagski
Re: No Stream
2022-04-08 083941.png (227.83 KiB) Viewed 76545 times
屏幕截图 2022-04-07 225559.jpg (244.28 KiB) Viewed 76545 times
Re: No Stream
note the about / registration dialog box is not useful here,
you may post the Voicemeeter system settings dialog box instead.
apparently your PC 192.168.1.238 does not see your iPhone in 192.168.1.121
could you use the command prompt tool to execute: ping 192.168.1.121 ?
(to check that you PC can see your iPhone).
