Losing my mind with the ASIO Patch
Posted: Sat Aug 27, 2022 5:54 pm
So... I've got my mics properly set up through a DAW that's passed to VoiceMeeter ASIO (Potato). 48khz & 256 on that ASIO (tried also everything between 128 & 1536, but nothing fixes the issue). Whenever I alt tab into a game or a fullscreen program when using VoiceMeeter ASIO patching it stutters like a mofa for a second or two. I feel like I've lost my hearing past few days trying to fix this (as the sound gets really loud, like a pop when it disables? my processing for that second or two). It doesn't happen when using Windows MME devices or WDM for that matter, but I can't use the DAW with those... ASIO4ALL works fine (kind of), but that requires me to change up my routing as I can't patch that straight to my inputs (I need to give up the output channel, VAIO3 for that).
Is there anything I can do to fix this? Tried running as admin already. Tried playing around with buffers. Atm on stock/default buffers (7168 & 512/1024). And it's not just one time thing, it happens every time I alt tab to a fullscreen program. Every time. Sometimes it might pop off while on desktop even (though, I think that's unrelated & I might've fixed it by changing the buffer from the 256 to 512).
