Windows 10: cannot connect to VM as audio device
Boffin
Post by Boffin »
I have been using VoiceMeeter V 1.0.6.0 on an older laptop (Dell Latitude E6240, Windows 10 Pro) without any problems for several years, with several audio applications.
I upgraded to an HP Elitebook 840 G5, also with Windows 10 Pro. I just installed VoiceMeeter V 1.0.8.2. Audio (e.g., from internet browser) works fine to internal & external speakers (via HDMI), but none of my audio applications can connect to that audio via VoiceMeeter:
------- Dell laptop + VM 1.0.6.0 ----------
VM output A1:
WDM Speakers (... audio device)
MME VoiceMeeter Input (VB-Audio VoiceMeeter VAIO)
> MME Speakers (High Definition Audio)
ASIO:ASIO4ALL V2
VM output A2: nothing selected
VBAN is off
MIDI Mapping - nothing defined
Windows Device Manager - audio inputs and outputs:
MIDI (VB-Audio VoiceMeeter VAIO)
other
Applications use audio source MIDI (VB-Audio VoiceMeeter ...)
NO PROBLEM
------- HP laptop + VM 1.0.8.0 ----------
VM output A1:
WDM Dell S2721SD (2- Sound Intel for display)
WDM Speakers (Connexant ISST audio)
MME Dell S2721SD (2 - sound Intel (r) p...)
> MME Speakers (Connexant ISST audio)
VBAN is off
VoiceMeeter Output (VB-Audio VoiceMeeter VAIO)
other
All my audio applications can see & select VoiceMeeter Output (VB-Audio VoiceMeeter VAIO), but when starting any audio functionality, I get the error "cannot open soundcard", "can't open audio device", "sound card used by other another program".
HELP PLEASE!!!
Thanks,
Frank
Re: Windows 10: cannot connect to VM as audio device
could you post a screenshot of Voicemeeter and its system setting dialog box?
Boffin
Post by Boffin »
Salut Vincent:
INPUT DEVICE: 5
IN WDM Microphone (Conexant ISST Audio) | INTELAUDIO\FUNC_01&VEN_14F1&DEV_2008&SUBSYS_103C83B6&REV_1001 | {2c384928-7637-442f-aabe-f6ed105445b3} | ICON: %windir%\system32\mmres.dll,-3020
IN WDM VoiceMeeter Output (VB-Audio VoiceMeeter VAIO) | VBAudioVMVAIO | {5a7c697d-8dd2-4212-b04e-01c94112e795} | ICON: %windir%\system32\Drivers\vbaudio_vmvaio64_win10.sys,-101
IN KS VoiceMeeter vaio | VBAudioVMVAIO | \\?\root#media#0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
IN MME Microphone (Conexant ISST Audio | intelaudio\func_01&ven_14f1&dev_2008&subsys_103c83b6 | {2c384928-7637-442f-aabe-f6ed105445b3} | ICON: %windir%\system32\mmres.dll,-3020
IN MME VoiceMeeter Output (VB-Audio Vo | VBAudioVMVAIO | {5a7c697d-8dd2-4212-b04e-01c94112e795} | ICON: %windir%\system32\Drivers\vbaudio_vmvaio64_win10.sys,-101
OUTPUT DEVICE: 7
OUT WDM DELL S2721DS (2- Son Intel(R) pour écrans) | INTELAUDIO\FUNC_01&VEN_8086&DEV_280B&SUBSYS_80860101 | {4805707e-4813-4775-aa39-931be96894ad} | ICON: %windir%\system32\mmres.dll,-3017
OUT WDM Speakers (Conexant ISST Audio) | INTELAUDIO\FUNC_01&VEN_14F1&DEV_2008&SUBSYS_103C83B6&REV_1001 | {9ca2ca7e-b88c-45fb-a655-9b5130f81ac1} | ICON: %windir%\system32\mmres.dll,-3010
OUT WDM VoiceMeeter Input (VB-Audio VoiceMeeter VAIO) | VBAudioVMVAIO | {2b3414d1-16d3-4eee-a45b-d1ef6f16619f} | ICON: %windir%\system32\Drivers\vbaudio_vmvaio64_win10.sys,-100
OUT KS VoiceMeeter vaio | VBAudioVMVAIO | \\?\root#media#0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
OUT MME DELL S2721DS (2- Son Intel(R) p | | | ICON:
OUT MME Speakers (Conexant ISST Audio) | intelaudio\func_01&ven_14f1&dev_2008&subsys_103c83b6 | {9ca2ca7e-b88c-45fb-a655-9b5130f81ac1} | ICON: %windir%\system32\mmres.dll,-3010
OUT MME VoiceMeeter Input (VB-Audio Voi | VBAudioVMVAIO | {2b3414d1-16d3-4eee-a45b-d1ef6f16619f} | ICON: %windir%\system32\Drivers\vbaudio_vmvaio64_win10.sys,-100
CHECKING VB-Audio Cable A : Not Installed
CHECKING VB-Audio Cable B : Not Installed
CHECKING VB-Audio VoiceMeeter AUX VAIO : Not Installed
CHECKING VB-Audio VoiceMeeter VAIO3 : Not Installed
Initialization value: 1
TEST DATE: 2022/09/04 - 19:12:06 (Checker Version 1.0.8.2)
Operating System: WIN 10 64Bits Build: 19044
CONCLUSION: OK (nothing bad detected)
Thanks for helping me out!
you may check you windows privacy settings regarding microphone and recording devices to be sure that they can be used by any application (including Voicemeeter).
Boffin
Post by Boffin »
I managed to get things working reasonably well (i.e., my audio apps can now select "VM input" as the signal source).
STEP 1: Win10 --> Start --> Settings --> Microphone --> "microphone access for this device is off" --> "on"
However, for some reason, VM inputs the microphone input - even though NO inputs are selected for Hardware Input 1 and 2. For some reason, VM accesses microphone continuously and I cannot turn it off in VM.
WORKAROUND: in Windows Taskbar, right-click on loudspeaker icon --> Open Volume Mixer --> Mute microphone input.
I still have anther problem: VM does not start up automatically at Windows startup. I have made sure that "Run on Windows startup" is selected in VM Menu. Also, in Windows: Settings --> Startup --> Voicemeeter: ON...
Boffin wrote: Wed Sep 07, 2022 12:04 pmHowever, for some reason, VM inputs the microphone input - even though NO inputs are selected for Hardware Input 1 and 2. For some reason, VM accesses microphone continuously and I cannot turn it off in VM.
don't understand this, or you have connected your Mic to Voicemeeter hardware input and Voicemeeter will use it 24/7 (then you can use the MUTE button on Voicemeeter directly - but the Microphone is still in use).
or your mic is not connected to Voicemeeter and it is not used at all by Voicemeeter.
Boffin wrote: Wed Sep 07, 2022 12:04 pm I still have anther problem: VM does not start up automatically at Windows startup. I have made sure that "Run on Windows startup" is selected in VM Menu. Also, in Windows: Settings --> Startup --> Voicemeeter: ON...
uncheck and recheck the option maybe, this is not a usual reported problem.
Boffin
Post by Boffin »
Well, I have uninstalled VoiceMeeter and installed VB Cable + VB Cable-A + VB Cable-B.
As I mentioned in one of my posts above, I use my Win10 laptop via HDMI with a display that has built-in loudspeakers.
I can only get the display speakers to work, if I make the display the "default device" in the "playback" tab of "Sound" settings. Unfortunately, in this configuration, I cannot make any audio processing application work with one of the VB Cables.
If I make a VB Cable "default device", then I can make my audio app work. However, now there is no more audio via HDMI to my display speakers, nor to the laptop speakers.....
you may have found a simple solution with Voicemeeter.
you must be able to connect any audio device to Voicemeeter, otherwise it means there is a problem.
you may go on our Discord server to find a helper who will check your config
https://discord.gg/TF42rahAXS
