Problem configuring VPN on voicemeeter (Problema de configurar VPN no voicemeeter)
shimatani
Post by shimatani »
Em portugues
Como faço para configurar corretamente entrada de stream1 através de uma vpn?
in english
How do I correctly configure stream1 input through a vpn?
Re: Problem configuring VPN on voicemeeter (Problema de configurar VPN no voicemeeter)
first point: check your VPN is a true VPN, not only a distant IP provider for internet browsing.
a true VPN provides local IP address to your computers and allows you to make a ping between them.
if the ping works, VBAN should work.
shimatani
Post by shimatani »
i have a vpn server.
and they are different addresses
I have a video on youtube showing
https://www.youtube.com/watch?v=65ngunmycR0
Note: it's in portuguese but i can translate it for you
as far as i see, it basically works, but you got many error during stream (on the VBAN Receptor).
in this case, you may go in VBAN Receptor menu and decrease the NETWORK QUALITY parameter to MEDIUM or SLOW
