VoiceMeeter has some bad random audio crackles issues
Posted: Sat Nov 26, 2022 4:09 pm
by MrKoddy
Hello there,
From yesterday, my Voicemeeter Potato has some bad random audio crackles issues. I tried everything, updated Voicemeeter, changing drivers in the app, relaunching VoiceMeeter, reinstalling drivers and Voicemeeter. But it has has some bad random audio crackles issues and I have to restart Voicemeeter. How can I fix this issue?
Regards.
Re: VoiceMeeter has some bad random audio crackles issues
Posted: Sun Nov 27, 2022 9:13 am
there is a dedicated topic on this subject:
viewtopic.php?f=6&t=451
Posted: Sun Nov 27, 2022 2:08 pm
by MrKoddy
I already did everything in the topic
Posted: Mon Nov 28, 2022 6:22 am
you may go in Discord to find a helper who help you to check your configuration.
there is surely a way to fix your problem (Be sure to use the Voicemeeter latest version).
Posted: Mon Nov 28, 2022 1:44 pm
by MrKoddy
UPdated too, same issue. I noticed issue began while I activated TPM 2.0 for preparing a Windows 11 update, I don't know if it is related. It was more stable before.
Posted: Tue Nov 29, 2022 8:30 am
stability problem in the windows sound can come from everything (but often from video driver or network driver activity).
in all cases there is usually a way to find a stable configuration with Voicemeeter (by tweaking buffer size, selecting right audio interface for output A1).
if you cannot find your working configuration, you may come on our Discord server:
https://discord.gg/TF42rahAXS
