Thank you so much for all the enhancements to Potato. I've moved from using a DAW now to just using the built-in functions in Potato for processing.
The feature I'd like to request is that for the noise gate threshold to have about 10db more in lower threshold range.
Simply I sit in an untreated hard wood room with a lot of cooling fans and other din and I prefer to run quite low gain levels on my USB interface to keep the room noise down as much as possible. This puts me right at the edge of the -60db minimum threshold, if it could go to -70 roughly it would fix the issue for me.
If I run the input up on the USB interface enough to break through this threshold, it's enough gain that with the Auto Makeup option on the compressor enabled, I can get near clipping and need to drop the input gain on the Voicemeeter channel down.
Great piece of software.
