VM requires very high CPU power
HGA1
Post by HGA1 »
Hi Vincent,
I have figured out, that VM Banana is using a lot ofthe CPU power.
I have a AMD A10-7860K Radeon R7, 12 Compute Cores 4C+8G 3.60 GHz
with 16 GB RAM and running the newest version of Windows 19.
In my opinion, a CPU usage of over 30% semms to be ver high.
There is only one input and output via VBAN over the LAN.
Can be these correct?
Thanks,
Hans-Georg
Re: VM requires very high CPU power
no, usual CPU load should be around 5%
maybe an audio driver is generating useless waiting cycle...
to be investigated...
