Potato install fails on new Win-10 installation
linuxgurugamer
Post by linuxgurugamer »
I've gone through this a few times now.
New Win-10 install, on new computer build
Motherboard has audio working before.
I have Voicemeeter Potato licensed and installed.
The user doing the install is the only user on the system.
I have gone through all the steps listed here: viewtopic.php?f=7&t=688
The install seems to work, but the drivers aren't working properly, I've included the output from the device checker below:
INPUT DEVICE: 3
IN KS VoiceMeeter Aux vaio | VBAudioVMAUXVAIO | \\?\root#media#0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
IN KS VoiceMeeter VAIO3 | VBAudio100VMVAIO3 | \\?\root#media#0002#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
IN KS VoiceMeeter vaio | VBAudioVMVAIO | \\?\root#media#0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
OUTPUT DEVICE: 8
OUT WDM Remote Audio | | {6C26BA7D-F0B2-4225-B422-8168C5261E45} | ICON:
OUT KS Realtek USB Audio | USB\VID_0B05&PID_1A16&REV_0003&MI_00 | \\?\usb#vid_0b05&pid_1a16&mi_00#6&21b7ae3e&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\waveout1
OUT KS Realtek USB Audio [A] | USB\VID_0B05&PID_1A16&REV_0003&MI_00 | \\?\usb#vid_0b05&pid_1a16&mi_00#6&21b7ae3e&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\waveout2
OUT KS Realtek USB Audio | USB\VID_0B05&PID_1A16&REV_0003&MI_00 | \\?\usb#vid_0b05&pid_1a16&mi_00#6&21b7ae3e&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\waveout5
OUT KS VoiceMeeter Aux vaio | VBAudioVMAUXVAIO | \\?\root#media#0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
OUT KS VoiceMeeter VAIO3 | VBAudio100VMVAIO3 | \\?\root#media#0002#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
OUT KS VoiceMeeter vaio | VBAudioVMVAIO | \\?\root#media#0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
OUT MME Remote Audio | | | ICON:
CHECKING VB-Audio Cable A : Not Installed
CHECKING VB-Audio Cable B : Not Installed
*ERROR MME Recording Device not listed.
*ERROR MME Playback Device not listed.
*ERROR WDM Recording Device not listed.
*ERROR WDM Playback Device not listed.
*ERROR TOTAL FOUND: 4
CHECKING VB-Audio VoiceMeeter VAIO3 (version 02010502)
Initialization value: 1
TEST DATE: 2023/04/28 - 13:09:24 (Checker Version 1.0.8.8)
Operating System: WIN 10 64Bits Build: 19045
CONCLUSION: 12 error detected (You may consider re-installing audio drivers)
linuxgurugamer
Re: Potato install fails on new Win-10 installation - Problem Solved
Problem is solved.
Turned out to be an issue with Remote Desktop. I am setting this computer up remotely, and for whatever reason, Voicemeeter can't work in a Remote Desktop environment.
When I tested locally, everything looked fine.
