Hello and thank you for the vb-audio software,
I need to do interviews, and I'll try to explain my current setup:
I have a laptop with Windows and I have a webcam and a microphone connected to it. Everything works fine.
I would like to be able to listen from the laptop (voices from the guests, so from Skype), but I have to stay some meters away from it. The solution would be a pair of Bluetooth earphones or a vb-audio product (I would prefer this solution, so in case there are other interviewers in the room everyone can listen from his own phone.)
Now the question: which products should I use? I tried VBAN lite for android with VBAN-Spot for Windows and I was able to listen to my mic, but not to listen from the speakers.
Am I using the right software? Could you please help me?
Thank you!
VBAN clarifications
Re: VBAN clarifications
any hint?
Thank you
Thank you
