Macro Buttons Context Menu Mnemonics
PeachBerry
Post by PeachBerry »
I would like to request a very minor feature for Macro Buttons.
Which is extra context menu mnemonics for "Shutdown" and "System Tray"
As you can see Shutdown does not have a shortcut right now, so I can not do "Alt + Space > S" because "S" is for "Size" but Q (Quit) is available.
Also for System Tray is "T" will be the mnemonic/shortcut.
Please consider this.
The reason I ask for this feature is because of a minor issue, sometimes the tray icon disappears and I need to either restart the program by "Shutdown" and re-open it or I can re-create the tray icon, by pressing "Alt + Space > T" (twice), which would create the tray icon again, without shutting down the program.
Best regards.
Re: Macro Buttons Context Menu Mnemonics
OK, done.
