Voicemeeter window size
jmcinvale
Post by jmcinvale »
Is there a way to alter the size of the Voicemeeter window?
I have Voicemeeter Banana, but want to try Potato as I could use more than three inputs, but am concerned the window won't fit completely on my 24" monitor running 1366 X 768 resolution.
Here's a photo showing how it displays.
I have three monitors in use.
1 Voicemeeter.jpg (215.71 KiB) Viewed 12545 times
Notice how it fills the screen completely and overlaps slightly on the other two monitors.
jmcinvale
Re: Voicemeeter window size
Post by jmcinvale »
For a 24" monitor that displays higher than 1366 X 768 resolution, text and icons become rather small to see, but 1920 X 1080 is needed for potato to fit on the screen because the application window cannot be resized.
Thing is I need to use potato because I have a four input usb audio interface and usb headphones with a mic and I need one stereo input and two mono inputs along with the USB mic input. Banana is one input channel short.
If the program indeed will not be changed to make the window resizable, is there a legitimate reason for that?
