guitar lessons via Skype: how to set VoiceMeeter
Posted: Mon Mar 11, 2024 2:32 pm
Hi Guys.
I downloaded VoiceMeeter standard version to have on-line eletric guitar lessons via skype with my teacher.
I use a notebook (Windows 11), an external audio interface (Behringer), a Neural DSP standalone plugin for guitar effects.
Guitar is plugged into the audio interface, which is connected via USB to the notebook.
I also need to play on backing tracks played by YouTube. I use the notebook mic and listen with earphones.
Target: I need my teacher to listen to me playing alone or on a backing track, he should be able to listen both my guitar (including plugin effects) + backing track + my voice. Of course, I need to listen to same from my teacher.
I tried different set ups, but cannot get what I need: sometimes I cannot hear the backing track, sometimes no plugin effects, sometimes huge latency… I guess I do not set correctly the options in Voicemeeter and/or plugin (input/output) and/or Skype… I've watched several tutorials, but still I'm doing something wrong: my fault, for sure.
Can you suggest the best set up for my needs?
I may try Banana or Potato, if I can get what I need more easily, or maybe I’d better use other platforms instead of Skype… I’m 100% open to your suggestions.
Tks a lot!
Tks a lot!
