Why two version of VB-Matrix installed?
Posted: Mon Apr 22, 2024 4:23 pm
When I did a standard install of VB-Matrix I got two versions installed:
One is called 'VBAudioMatrix' and the other is called 'VBAudioMatrix 64'
However in my Windows app list it shows only one listing 'VB-Audio Matrix, Audio Router'
Which one should I be using or are they actually running the same programme?
