I have experienced this issue for several years of use and it's rather annoying but I've never posted about it and it used to happen on my old headset (Logitech G533 Wireless) and also on my current headset (HyperX Cloud II Wireless).
The issue happens seeminly randomly where out of nowhere all audio becomes super crackly and fuzzy. If for example I am listening to music I can still hear the tune kinda through the fuzzy but it's like listening to a radio/old school tv trying to find a channel, that white noise.
If I load up VoiceMeeter and click on Menu > Restart Audio engine it returns to normal. It happens probably once every other day on average. I had to setup a macro to restart VoiceMeeter because of how commonly it happens: https://i.imgur.com/wCP6fxw.png
I've tried following all of the steps in viewtopic.php?t=451&sid=516281a2051931d ... 49ce1b4013 but none of them have helped find a solution to the issue...
Thanks
VoiceMeeter Crackling/Fuzzing Audio Issue
Re: VoiceMeeter Crackling/Fuzzing Audio Issue
you may post screenshot of your Voicemeeter and its system settings dialog box.
be sure to use the latest version.
