Any issues reported with 2024 Release (Banana?)
Posted: Thu May 02, 2024 2:36 pm
Hi there, not sure if this is just a coincidence, but I just installed the new version and had a few problems last night during a live session
#1- About 45 minutes after starting the ZOOM session using Banana, my PC just froze hard. Had to hard reboot. At this point, I didn't even suspect Voicemeeter at all.
About 20 minutes after that reboot, remote users reported loss of audio. It appeared as if Voicemeeter Bus B1 was no longer routing output to ZOOM. I did the Zoom audio check and confirmed this. In desperation, I closed and restarted Voicemeeter. Without touching any other setting, everything worked fine after restarting voicemeeter. I was surprised- I thought when voicemeeter was closed it would remove all of the virtual IO devices and the zoom settings would go back to the defaults, but that didn't happen.
Setup is Windows 10. In-person meeting (~40 persons) with three microphones mixed down into Banana and then into the Zoom session. I eventually deciphered the French youttube video to get all the setting proper regarding the default communications devices in the windows sound settings
Is the prior version available for download somewhere? I'm wondering if I should rollback for the time being to see if there's any bug fixes necessary with the new version.
Thanks!
Thanks!
