I`m a total noob with the matrix.
What i have, tr8s and tb3, fl studio and a NI Z2 with build in audiocard i use.
I can get the matrix to work with the tr8s and fl studio. What i`m understanding is you set the outputs of the tr8 to the inputs of the asio channels in the matrix. After tis i set the audio input/output of fl studio to the designated asio used in the matrix. Now i can select the channels of the tr8s on my mixer channels in fl.
So far it works but i have no sound. The setup in windows confuses me because all the extra channels
attached screenshots. Thanks in advance
Noob needs help
Noob needs help
- imresizer-1719779602573.jpg (449.38 KiB) Viewed 1130 times
- imresizer-1719779631882.jpg (470.4 KiB) Viewed 1130 times
- imresizer-1719779656284.jpg (466.66 KiB) Viewed 1130 times
Re: Noob needs help
All ready figured it out my self. Adding the Z2(audiocard) to the matrix will do the trick, connected with the virtual asio 64 i/o in the matrix
