VAIO Extension tabs no longer showing after update to 3.1.1.3
PresidentJade
Post by PresidentJade »
Bonjour,
I updated my Voicemeeter Potato from version 3.1.1.1 to 3.1.1.3
And now, the VAIO Extension tabs are no longer showing on the VM Potato interface.
How do I get these back?
Re: VAIO Extension tabs no longer showing after update to 3.1.1.3
simply check your license activation in menu (VAIO extension license).
PresidentJade
Merci pour la réponse rapide, Vincent :)
I used the 1 regen available in my webshop account to reactivate the VAIO Extension License (originally purchased March 10, 2024). I was a little confused of having to use a regen since the VAIO Extension had always worked before and I only experienced this issue after updating to Potato 3.1.1.3.
As a courtesy, the Support at your webshop replaced the regen code that I had used. Unfortunately though, the VAIO Extension buttons were still not appearing on my VM Potato interface despite reactivating the VAIO Extension license.
So I used a regen to re-activate Potato. But still, no luck having the VAIO Extension buttons appear on the interface. So I again used a regen on the VAIO Extension (the courtesy regen that the webshop had added in my account). And this time it worked. The VAIO Extension buttons appeared on my Potato interface. Merveilleux !
It was a confusing experience for me, and it is unfortunate that I ultimately had to use the regens in the webshop for both Potato and the VAIO Extension. But this time I've learned to export the footprint to avoid similar situations going forward. And if I were to ever experience the same issues again, I would simply buy/donate for a new license since we can't go wrong in supporting the awesome products that you create.
Une fois encore, merci pour la réponse rapide !
Bonne journée :)
Thanks for reporting the context.
The version 3.1.1.3 is implementing a new code system (more stable, more secure) that's why you had to reactivate your license but you have found a REGEN in your account "My License" page (this has been added to all end user accounts in June).
More info: viewtopic.php?f=6&t=878
BTW: all questions related to license or activation code problem must be addressed to our webshop support instead: https://shop.vb-audio.com/en/contact-us
