Voicemeeter and Scarlett Solo 4th Gen
bhopp
I use my setup for Zoom, Teams, Google Meeting, and Google Voice. I need my pc audio to go to the speakers, but would like to keep the mic out. I cant EQ the mic with adding it to the computer mix. Is there a way to do this?
Re: Voicemeeter and Scarlett Solo 4th Gen
yes, you typically may try Voicemeeter Banana.
bhopp
I already purchased Potato, works great for the PC Audio, but I cannot EQ the Mic Audio coming from the Scarlett without having it in the same mix as the default stream, there is not enough choices on the In's, and Out's. It's like I need a mic preamp with EQ wired in between the mic and the Scarlett. Is this possible? Is this what the cables are used for?
i'm afraid i don't understand your problem, could you post a screenshot of Voicemeeter and explain what you want to do exactly ?
