Recorder / Soundboard Macros / Audacity weird issue
Posted: Sun Nov 03, 2024 7:07 am
Hi guys,
I'm trying to set up a soundboard with the Macro Buttons feature. Great tool!
I'm having a weird issue. If I load up a "factory" mp3, everything works just fine. But there's a bunch of stuff I want to edit and create clips, etc., and I'm using audacity to do that. No problem there- I can edit, trim, etc., and save as either MP3 or WAV. These trimmed files play fine in windows media player. However, not so much in the recorder. It does nothing. I'm watching the recorder just above the Master Section, and it doesn't even load the filename. I've tried exporting the file as both a wav or MP3, but still bad results. Not a whole lot of options when I export from audacity- basically just the bitrate. And I've tried the highest and the defaults. To reiterate, these files play just fine in WMP, but nothing when I try to play them in Banana via the recorder macro.
Any ideas? Thanks!
Any ideas? Thanks!
