Where are the xml settings files?
dibbs25
When you save VM settings you give them a filename and if you reload them at a later point it looks like you are opening the xml file you created, but if you go to the folder in explorer the file isn't there. The data has been stored somewhere, clearly, but can anyone tell me where?
Re: Where are the xml settings files?
Voicemeeter settings files:
They are also copied in "My documents \ Voicemeeter"' folder.
(where Today and Yesterday settings are also stored).
- VoiceMeeterDefault.xml
- VoiceMeeterBananaDefault.xml
- VoiceMeeterPotatoDefault.xml
