AsIO.sys blocked by Windows 11 24H2
KeiserSoze
Post by KeiserSoze »
does anyone experience that Windows 11 24H2 blockes AsIO.sys drivers. I'm not sure but I do not have any device that should use AsIO.sys drivers (maybe I do and I'm not aware of it). ASIO (Steinberg) option in Potato are disabled (grayed out). On Windows start I get message that those drivers are blocked by windows, and I just want to get rid of this message by removing drivers I don't need.
Can anyone help me with this?
Regards,
K.
Re: AsIO.sys blocked by Windows 11 24H2
it seems you are not alone with this problem (but it has nothing to do with VB-Audio).
https://answers.microsoft.com/en-us/win ... 0d445af89f
KeiserSoze
Vincent, thanks for the reply. I was 100% sure it's not problem with VB, but I am searching for a solution. It seems to me that I do not have any uninstall program available, as none of the mentioned programs are installed, so I have taken drastic measures and renamed file (didn't remove it for just in case).
K.
