Control VoiceMeeter with LPD8 Midi controller
Skirner
Post by Skirner »
Hi.
I just bought the Akai LPD8 controller, and it works like a charm with VoiceMeeter. But is there any option to set "toggle" to mute or kind of "push to talk" on the mic input in VM?
For example, I've set the pads as toggle in the LPD8 Editor, so the pad stays lighten up when pressed and turns black again the next press.
It would be awesome if i can set it in VM so that when mic is muted my pad is lightened up, or vise versa as "push to talk" so that it's lighten up when "on air".
Hope you understand what im trying to say. :? As i'm very new to all this kind of stuff, so if there is a way to do this already please explain. As i don't really knows what all those CC, PC, etc is for. :oops:
I'm using VoiceMeeter Banana and I Love it! Got it hooked up to my Presonus AudioBox 22VSL, Butkicker and DTS to my receiver.
You guys simply rock!
Thank you very much for this superior piece of software.
//Skirner
Re: Control VoiceMeeter with LPD8 Midi controller
Thanks for your comment and positive feedback,
i'm going to see how to add an option "Push To talk" on the Mute button MIDI Mapping for hardware inputs...
Skirner
Post by Skirner »
Thank you very much.
It would be awesome if you get this to work.
Skirner
