Voicemeeter Banana Release
Voicemeeter Banana Official Version 2.0.0.7 (includes also Voicemeeter version 1.0.3.4)
DON'T FORGET TO REBOOT AFTER De-Installation and Installation process
PRESS RELEASE JAN 2015
VB-Audio Releases New Virtual Audio Mixer: Voicemeeter Banana !
Voicemeeter is revolutionizing the way audio is managed on Windows PC's. It is now possible to connect and mix any audio source(s) with any audio application(s) in an easy way with unparalleled control on sound quality. DVD players, USB MIC, ASIO board, Video Game, iTunes and audio pro DAW can be connected together with Voicemeeter and provide incredible new audio experiences!
Voicemeeter Banana comes with more I/O and a brand new 'next gen' audio engine creating new routing / mixing possibilities by managing 3 hardware sound cards and 2 virtual audio devices in a simple straightforward approach. Endowed with new effects on all input strips, a High End Master Parametric EQ on every Bus and a multi format audio player/recorder, Voicemeeter Banana emerges as the most advanced audio mixer for windows and a “must have” system audio component.
Voicemeeter Banana
Voicemeeter Banana
Originally developed for VOIP users and PC gamers, to mix voice and music on Skype, Google Voice, Lync, Teamspeak and others... Voicemeeter has also become the 'go-to' app for Broadcasters, Podcasters and YouTubers, providing essential tools to manage many different audio needs: To improve voice quality on any microphone, record interviews or conferences in multichannel or mixed stereo, simply managing audio in a consistent way under the Windows operating system.
With Voicemeeter Banana, VB-Audio Software has once again widened the expanse of computer sound, opening up new possibilities for virtual audio mixing. With 8 Channels, 6 Cells, and Full Parametric EQ on all busses, you can now correct 5.1 or 7.1 diffusion or use the multi-channel EQ as a Crossover to drive 2, 3, or 4 way Stereo P.A. Systems. The Integrated Tape Deck will RECORD or PLAY any audio sources or audio files with a single click of your mouse (WAV, AIFF, BWF, MP3 + MP4, M4A, MOV, AVI, WMA, WMV…).
Voicemeeter Banana also offers two virtual ASIO drivers to connect your favorite pro audio DAW and it introduces the concept of “virtual insert” through a third ASIO driver called “Voicemeeter Insert Virtual ASIO”. For example, it allows you to use VST PLUGINS through a VST HOST application like Minihost Modular as an insert on every pre-fader input. Then every input can have its own VST PLUGIN CHAIN to process any of your audio sources before it goes to the final mixer output(s).
Partneship !
VB-AUDIO is looking for partners that are interested in bundling Voicemeeter with VOIP applications, Audio DAW’s, Broadcast Solutions, headsets, audio boards and all who would find it useful to purpose Voicemeeter as add-on to their solutions.
Fair trade, affordable for everyone!
User friendly design with the highest audio quality in mind, VB-AUDIO takes VIRTUAL AUDIO MIXING to the next level at a price you can afford. Voicemeeter is distributed as donationware, free to download and free to use! It allows you to set the license price according to your means, if you find this application useful. Thanks for your participation and support! Feel free to contact us for volume licensing of special deals.
Windows XP, VISTA, WIN7, WIN8, WIN8.1, 32/64 bits (MME, WDM/WASAPI, KS, ASIO).
http://www.voicemeeter.com / http://www.vb-cable.com /www.vb-audio.com
RobertVO
Re: Voicemeeter Banana Release
Post by RobertVO »
Congratulations on the release. Nice New Year's surprise.
Cheers
Voicemeeter Version 2.0.0.8 corrects last minute bugs.
- Potential crash (mainly with Banana) when using in output A1 some ASIO device with different number or input and output.
- Check Consistency in A/B management of the EQproG6 in Voicemeeter Banana (closing the dialog box was losing the A/B states and settings).
http://vbaudio.jcedeveloppement.com/Dow ... _v2008.zip (Don't forget to REBOOT after de-installation and installation)
We also suspect that the output channel number of output A2 and A3 could depend or be limited by the A1 device's number of channel, it's now sure that A1, A2 A3 are independent in term of number of channels (means A1 can be stereo, A2 can be 5.1...)
