Voicemeeter Version 2.0.1.1
Voicemeeter Banana version 2.0.1.1 (and Voicemeeter 1.0.3.6)
are now available by this Direct Download Link:
http://vbaudio.jcedeveloppement.com/Dow ... _v2011.zip
(REBOOT after installation and de-installation).
Alternative Link:
http://vincent.burel.free.fr/VirtualAud ... _v2011.zip
Corrections and new functions:
-PLAYER / RECORDER: removes various bugs (potential transport inconsistency and possible buffer repetition every period of 5 to 20 min… possible freeze).
-MME devices could not work on banana because 24 bits format negotiation is not really possible with MME interface.
-Better Sleep / StandBy / WakeUp management.
-Settings are now stored correctly on Windows Shutdown.
-PLAYER: pushing STOP goes to ZERO
-Add F5,F6 and F8 keys to Start Stop and Record
-Add ASIO Input Patch under Output Device A1 in the system settings dialog box, to route ASIO input into physical input strips.
RobertVO
Re: Voicemeeter Version 2.0.1.1
Post by RobertVO »
Thanks for the update!
Cheers
Robert
