SONAR X3 shows Grayed (Disabled) ASIO Drivers
SONAR X3 shows Grayed (Disabled) Voicemeeter ASIO Drivers and you think it is not possible to select another ASIO Device!?
it's because SONAR X3 can use a single ASIO driver at a time and then disables all others.
So if using M-Audio ASIO Driver for example, all other ASIO driver will be disabled (grayed).
To make them active again and select another ASIO Driver in SONAR X3 you need to
1- deselect all inputs and all outputs.
Then all drivers appear activated.
2- select inputs for the wanted ASIO driver for example the Voicemeeter ASIO Virtual device (and select the outputs).
