Figured out the flaw with WDM and Microphones
ShamisOMally
Post by ShamisOMally »
So I finally figured out what is causing the problem with WDM and microphones
It all has to do with the noise gate
If the noise gate is off, I have zero issues indefinitely
If noise gate is on, after 2-4 hours the sound gives out and it starts pulsing on/off rapidly, like some weird reverb
REstarting Banana fixes it for another 2-4 hours till it fails again.
If mic is in MME mode, it works forever without issue even with noise gate on or off.
Re: Figured out the flaw with WDM and Microphones
well, this is strange, because it is the description of the possible problem caused by WDM Input Exclusive Mode option...
anyway, i will check the gate too.
please, let me know the Voicemeeter Version
and if you can, post a screenshot of your system settings dialog box (see in Voicemeeter menu).
ShamisOMally
2.2.2.3
I'll try taking off exclusive mode, but prior I had no issues with it before windows 10
Also I had to increase the wdm sample rate cause SBZ and MXL mic both exceed 512 all the time causing static.
*EDIT1*
Nope, Mic in WDM mode after 6+ hours failed again, and full of static
ha, could you make the test with option Engine Mode = Normal ?
Other possibility:
select your speaker as output A1 and Elgato device as output A2 (Output A1 is giving the master stream and might be connected to physical device).
Last option: install back the official version 2.0.1.1 (don't forget to reboot after de-installation and after installation) and perform the same test...
