Feed two headsets with the same audio?
Bernard
Post by Bernard »
Use Case: I have 2 USB headsets and I want the windows default audio to feed both headsets. Will VB-Audio help me do this?
If not, what would it take?
regards,
B.
Re: Feed two headsets with the same audio?
yes, you can do that with Voicemeeter or Banana version (that are virtual audio mixer)
download and user manual on www.voicemeeter.com
(REM; VB-CABLE is a simple virtual cable to connect 2x applications together).
